Hi
Along with attempting other work arounds, I've been trying for hours to get the sweep to work consistently for all spines which were imported as a PDF (exported from Affinity Designer). In Affinity Designer, I have redrawn the lines. I have reversed the curves. I don't know what else to do to get these two swept splines facing the same way as the others. It's not a problem if I use a four or eight-sided spline because when flipped around, they look the same. But for sweeping custom profiles, this is something that I would like to solve for other designs I'm planning.
One of the other attempts to get this pattern to work was to draw a quarter of the pattern and use symmetry modifiers to reflect the quadrant in both the x-axis and the y-axis. That solved the above problem, but then I ended up with having to join up the ends. I tried point slide, but could not snap them to vertical or horizontal. The snapping was always a couple of degrees off.
Any help will be greatly appreciated. I have attached one of the PDFs for reference.
This is rough draft of what I'm trying to create below for a wallpaper pattern. It's for a Spoonflower competition and due tomorrow, but I'm not fussed about missing the deadline. I'll still put this design up for sale.
I also intend to replace the n-gon shape with a custom vector shape. My first attempt was a disaster thanks to the problematic splines. Plus the profile / cross-section needs a lot more work.
Thanks in advance for any help offered.
Chris
Chris
