F-Curve Controller.js - v7+ only
Hello,
It's a tag script to control other object's f-curve with attached object's f-curve. available only v7+.
its parameters are almost same as F-Curve Linker.js..
tag index: -1 means attached object, and if 0/1/2.. means index of tag ( usually 0 indicates mode tag of attached object)
parameter: select which parameter you want get to control
p.name: if you select 'other' at parameter, you can input parameter name manually. in case you use material parameter, it will be 'material.[node id].[parameter name]'.
get for: which value you want to get from Vector value ( x / y / z, h / p / b )
check parameters: you can check parameter's name of current settings ( you can check [node id] with this button )
target object: target object to be controlled
target tag index/target parameter/target p.name/set for/check target parameters: same as above, but for target object.
formula: you can input formula manually as javascript, it should contain v character as get value. for example.
multiplied by 2: v * 2
divided by 2: v / 2
sine: Math.sin(v)
floor: Math.floor(v)
Best.
tg_jp, Hiroto
This may sound like an odd question, but is it possible to use this (or, Linker, but I assumed that doesn't work in v7) to do things like tail wobble or fat jiggling?
I was playing around with Linker and I came close to a tail wobble. By this, I mean a tail that sort of moves up and down and around while a character walks.
Thanks!
Bob
here is a sample, please check it.
Best
tg_jp, Hiroto
  • f-curve_sample_01.jas.zip
Pretty neat! I'll have to play around with that.
Is it happening automatically, or are you animating any parts of it?
Can it be made to have a falloff, meaning, if you grab the base of the tail and move it, then stop, the tail eventually comes to a gradual rest.
Bob
in this sample scene, I attached 3 F-Curve Controller.js tag to "body" object. all 3 tags control certain objects with body's z position.
1st: x position of "tip target" object ( target object of IK handle ) with formula Math.sin( v ) * 0.5.
2nd: y position of "tip target" object ( target object of IK handle ) with formula Math.sin(v*2) * 0.1.
3rd: b rotation of "neck" object with formula 38 + Math.cos(v) * 20.
about "falloff", I think you can use "Point Constraint" tag attached to IK Handle's target and some value for weight. without F-Curve Controller.js script.
Best
tg_jp, Hiroto
I'll have to digest all that!
Thanks for all the information. I wish I could code. I have lots of idea (rigging, animation) but can't follow through with them.
Bob
