Different clothes? Particle guys
I'm trying to do a crowd scene but don't want everyone dressed alike any way to have different textures on these guys?
* Not sure if this useful combined with your animation:
* Duplicate / triplicate the BB / BlankBoi and change the colour of the “uniform”. The particle tag will still generate different size variations for the red / green / yellow BBs.
Here's another way, one texture based on position.
  • Organic Mix.c3dmat.zip
I was hoping to get away with only one figure.
* There is a thread entitled Particles w. different colours which explains this.
* The logics is quite simple, really: the gradient node is fed by the instance node, thus different hues are applied to different instances of the elements in a particle mesh.
* In this thread, Frank has also included a screen shot which shows this in the node editor. I have copied that into this thread.
* A great example of the serendipitous :)tongue: another great word to throw around in the pub) joys resulting from lateral thinking.
Where in this example would I place my texture image? Sorry to be so dense.
* Oops, I am not sure as I have never used this trick myself.
* If you upload the .jas BlankBois file (simplified / without joints, etc), I check this with a few tests.
* Don´t worry about density. It´s the vacuum that makes the brain implode :frown:
  • Like
Reactions: DEO
@ZooHead
Yes as you see in the OP the guys have textures faces etc that I would want to change on each instance, I have gone ahead and just created individual figures to make my crowd scene.That way I can pose each guy differently.
I don't think what I wanted from the OP is possible anyway.
@Helmut: I have gone ahead and just created individual figures to make my crowd scene.That way I can pose each guy differently.
I don't think what I wanted from the OP is possible anyway. But Thank you for the offer of help and the density comment, very witty.:smile: :icon_thumbup:
Differentiating particles
I was recently trying to figure out how to make particles more diverse, either randomly or with precision. As usual, I made a couple of pictures to document the process for future reference. I attach them here in case anyone else might find them useful.
Random color material:
Instance Random + two gradients + (E.g.) Voronoi
Particle Tag + Instantiate color
Random Position/Rotation/Scale:
Particle tag
Precise Position/Rotation/Scale:
Hiroto's Referenced Particles Script
http://www.tres-graficos.jp/blog/files/article.php?id=105
http://www.cheetah3d.com/forum/showthread.php?t=10374&highlight=referenced+particles
Sorry it took a while: I got side tracked.
  • Blank Boi for test.zip
Not sure if this ever been solved.
If you could go away with a polygon selection (you might need to scalpel new edges for the clothes and the rigging is obsolet then in this chronology, because new geometry destroys the joint weighting - as you know) - you can assign a new material to just that selection and add instance+gradient nodes to alter the colours on that particular part:
  • Like
Reactions: DEO
