Copy Object, Slice Object, Fill Holes.
I am looking for a way to programmatically slice an object up and fill in the blank walls on the sliced sides.
It will be intended for a video game and the object is pre sliced up and lives inside the original shape until destruction time.
I can do it very slowly with boolean but would prefer a script if something exists.
There´s no script I´m aware of - but the new Boolean tool will be more than sufficient to do so.
Hi Frank, that is how I am doing it now as well.
I was hoping someone might have one that is automated and closes the holes.
* You may want to look at the jas sample for Rigid Body 2 in the help menu in the folder for dynamics.
* Substituting the simple cubes in this example with more complex polyhedral cyclopean masonry (where each block is a cluster of 2 or more elements) should get you to the required effect of a tank turning a wall into rubble.
Testing the script above.
What Have I missed>?
Script is in Polygon Obj
Cheetah has restarted.
Script is obviously not in its specific place and what do you expect from that box?
The script is called Voronoi Plane for some reason. :D
It goes: Mac/HD/Users/User/Library/Application Support/Cheetah3d/Scripts/Polygonobj
Sorry Frank, obviously silly on my behalf, trying to go too fast, I was putting it in the scripts folder within the application and not in the application support.
P.S.
Some of the edges are still welded but this is good enough for me to get something started, thanks everyone.
PPS Solved the edges case. not firing on all cylinders today guys.
Here is the process I was hoping to automate in case someone knows how.
Make Plane
Add Material
Name Material : Fragment
Add Voronoi
Drag plane into Voroni
turn off inner edges
adjust site count
collapse voronoi
Select a face
Disconnect
Split
and then shell each new mesh
Repeat until all faces are disconnected, split and shelled.
Shell gives me a weird irregular height even when not adjusting anything between usage.
