How render LEDs on device
Hello,
The Device has Clear Light Pipes that cover LEDs.
Problem: The the light from the LEDs that I have now spills out of desired area and creates too much reflection on the enclosure. I have to PhotoShop the spillover out of the image. Is there a good method for making LEDs?
Thanks,
QCI1
Hi QC11,
It's a little hard to give specific advice, since I'm not sure exactly how you've modeled this. If the lights are a separate object from the body, you could try using a render tag to exclude just those reflections.
I ended up using the Solid Material with high intensity for the LED inside of a light pipe that has Blurred Glass as the material. No reflections are on the enclosure now, so no need to PhotoShop it. I don't think they look very LED-like, though.
Thanks for the help!
Yeah, there are no volumetrics in C3d yet, which is what we would need to create a proper glow type of material look. There are a few different ways to work around it, at varying degrees of difficulty. You can search around the forum for some of them and give it a shot. It may be easier for now to do a few separate render passes and do the glow in post in an image editor (like Photoshop, GIMP etc.).
I now made each LED with a Spot light inside a Capsule. The Spot light points down. 4 LEDs are in a light pipe. There are 3 pipe lights. I think the rendering shows a better bounce of light within the light pipes and the reflection on the enclosure is gone.
Looks great! Nice work around.
