Creating morphs from seperate meshes?
Hello,
I have 2 meshes with near identical poly,tri count.
Is it possible to create a morph from 2 or more meshes?
Thanks!
Is there a tut for creating morphs from a sequence of meshes? Or maybe just a quick hint on how it's done?
As said it will only work with identical topology and polygon count.
Just add the morph-target to your first mesh hit the plus button (give it a name)
Take the morph-target and drag it to the next mesh in object-browser: hit the plus button (give it a name).
Take the morph-target and drag it to the next mesh in object-browser: hit the plus button (give it a name). And so on.
At least drag the the morph-target back to the first mesh.
Use the slider to adjust each recorded mesh status separately or everything to your liking. Simple sample file attached:
  • 3_morph_Targets.jas.zip
