Text Spline Around a circle
Hi there
Is it possible to set a text spline around a full circle, much like for creating a dial for a clock or a compass.
Any help would be great.
Illustrator or similar program would do the job.
Hi
Thanks for the quick reply. Would this be converted to a spline? As I need the text to be engraved on an object.
Hi
Yes, in Illustrator convert to outlines, then make it a compound path and save as SVG. In Cheetah use import.
Extra tip: In Illustrator, move it close to the lower left corner of the document before you
save as, that corner will be the world center point in Cheetah. It makes it easier to find.
hi
thanks again for ur help. I've followed your advice and have imported a text as an sag file. However I can't seem to create anything with it.
Can I extrude the text. Or perhaps find a way to engrave it to an object.
hi
To extrude use the Extrude Creator, just put the spline into it and experiment with the settings.
Be careful, Cheetah doesn't stop you from making a mess.
Low bevel settings are best with enough sections. (I used 5)
And check the internal structure in wireframe mode to see if it's messed up.
Insetting the text is possible with a Boolean Creator, but it makes all triangles,
which is not the best. Also a Displacement Modifier may do what you need.
No need to leave Cheetah3d for this.
Fully parametric set up:
  • Dial.jas.zip
Just to add, the all Cheetah method (red)
distorts the text, the Illustrator method doesn't.
While all deformers do what they do I was a bit unmindful; a larger radius at the wrap-modifier will almost recreate the font shape:
Can you send the file over, I'd like to see your WrapMod settings.
I'm trying to understand them all and I'm having some trouble.
