Medieval Town Construction Kit
Medieval small township
* This is an exercise in particle meshes. In practice, it is a construction kit which allows you to generate a variety of different buildings by “plugging in” the predefined panels.
* Each house consists of a - more or less - simple box in a metric of x*y*z sections and units.
* The individual 1*1 faces of these boxes are assigned shade selections to differentiate “panels” which will be doors, ground floor windows, upper floor windows, oriels, etc.
* Predefined panels for doors, different window configurations, etc (see note on attached library below) are then assigned via the particle mesh function (type polygons + polygon selection n).
* A small library of door / window elements and building templates is supplied. Enlarge this collection according to your requirements
* I hope you have fun.
* Attention: Stacked particle meshes are not currently supported on C3D 6.3.2. The 2nd level shows in the editor but does not render. For renderings / animations, you need to turn the PMs into meshes to achieve a result.
Cont´d
Example for the town hall
* The wire mesh shows the PM base box, in this case a simple 3*3*3 box with a twiddled roof
* I have offset the various panels for the frontal / sidereal facades and the turrets.
Libraries
* See attached Zippies.
  • PM Library.zip
  • PM Buildings.zip
* Needless to say, PMs can be used as constructors for any complex building with repetitive elements.
* Screen shots for a few examples.
And now for something completely different
* Equally needless to say, PM constructors are quite useful for models pertaining to other areas of knowledge modelling.
* Doodle for Hawking radiation.
Wow. Excellent building blocks. Artists are always looking for quick ways to add complexity to their scenes. Nice workflow.
Bums.:frown:
Does anybody know how I can upload the bundle of .jas plus the associated .c3dmats? I would like to simply post the unedited (PMs double level; shows in editor but does not render) and edited (PMs > meshes; can´t be modified but renders) models for the townscape.
It would be of great advantage if users could download the entire townscape for experiments.
Heeeeeeelp :confused: :confused: :confused:
Servus from Vienna
Townscape 05: Model with individual PM buildings. Note that these won´t render.
Townscape 06: Model with PMs exploded into meshes.
Unfortunately, the final models are loo large to upload.
  • Townscape 05.jas.zip
  • Townscape 06.jas.zip
You are welcome.
There is a construction kit on space ships in the works. It all takes a while :redface:
Cheers to Kiwi Land :tongue:
Really cool stuff. I love to see Cheetah3D in the context of theoretical physics.:smile:
Bye
P.S. Beautiful skyscrapers too.
