Ball or Lathe?
Ball or Lathe?
Hi
I have a problem with the ball on this logo. I want the ball to look solid with groves taken out.
I have got this far by deleting relevant polygons from a ball, not sure now how to fill the gaps... or should I have used an effect (lathe?) on the original svg of the .svg shape?
Thanks for any help
R
That is easy. Use Fill hole on the gaps; will look messy in first place - but when you make 2 scalpel tool cuts - everything will be fine:
PS: added file
  • SlicedSphere.jas.zip
Hi Frank
Works on top section but middle section the back does not fill and/or scalp properly and the bottom section the top does not fill and/or scalp properly?
Use optimize tool first to get rid of useless points from the deleting!
If all failed call Create Polygon tool - file the back with one 6-sided nGon each and use fill hole then for top/bottom.
Simple Method
1 select faces in area mode
2 apply a small inner extrude
3 squash the selection into a plane via the scale box of the transform widget
4 move back (snapping @ raster) to the centre axis via the transform widget
Ooops, of course you are right:rolleyes:
(maybe I should add this to my default signature to save time typing it over and over and over ... again)
Prost nach Hamburg
I got some weirdness see image.
Hi Uncle Bob
Yes, these are the artifacts Franks has solved with his sanitised version of my method. I actually felt this was a minor bit of rubbish, but did not zoom in to look closely. Sorry
Greetings from Vienna:tongue:
