SVG import bug.
SVG import bug.
I aways got this problem when export svgs from inkscape to Cheetah, also on Blenders the svg looks ok.
  • drawing-1.svg.zip
When you scale the drawing to fit onto the page it loads fine here into Cheetah3d:
I opened your svg in Adobe illustrator, removed the fill color and the stroke (these aren't needed for this job) and the file loaded fine in cheetah.
It seemed to have gradient stroke around the edge and this could be throwing cheetah off.
Here still not working, i tried to remove the fill and gradients also scaled the page to be bigger than object. Maybe a inkscape incompatibilitie?
On atach the new svg file.
Thanks for attention.
  • drawing-1.svg 2.zip
His first file didn't work in cheetah, like he said. Re-saving as svg using illustrator re-sets the files co-ord system and it then works.
Same Inkscape (I had 048.5 already installed - but all add-ons are no longer working - so I downgraded. :frown: :rolleyes: :redface: )
but Cheetah3d 6.3.1
