OK, here’s the long version…
I’ve created a set of sine-wave splines, interspersed with each other, combined into one complex spline. Put this in a sweep creator with a circle or n-gon, add a nice material, and you get a good wire grill. (Pics 1 and 2)
What I’d like to do is reshape these splines into a hemisphere shape, much like the magnet tool (set to ‘circular’) does with polygons. Why? In order to make Pic. 3.
To make the wire grill of a microphone, you have to push the spline points into a hemisphere shape while still keeping the same arrangement between the ‘up’ and ‘down’ points. From what little I’ve read on the ‘net, other 3D programs do this by ‘attaching’ the splines to a plane, distorting the plane to a hemisphere, then copying the re-shaped splines, but Cheetah has not this ability. Creating a sweep and using polygon modifiers isn’t an option, as the polys tend to get distorted at the edges and it’s hard to get the correct shape. What I want is a way to re-shape the spline, then add the sweep.
So I had the idea of making ever-decreasing circular selections of spline points and raising them to match the contour of a hemisphere. To illustrate this, I carried out a similar process with Area Select. I placed a half-cylinder over my spline. In Bottom View, I used Area Select to make a square selection of almost all the points in the spline. I activated the Transform tool, fixed the gadget to one of the outer points of the selection in Gadget Mode, then moved the selected points up until the outer points intersected with the half-cylinder. In Bottom View again, I made a smaller selection with Area Select (one ‘row’ in from each side) and repeated the process. I kept going until I’d worked to the central points of the spline (Pic. 4). Pic. 5 is the result. Note that each ‘wire’ is the same diameter throughout.
If I could do the same with circular selections, radiating from the centre, I reckon I could make my microphone grill. Area Select’s rectangular selections won’t do the job. Hand- or paint-selecting points is fiddly and likely to be inaccurate. Expand/Reduce selection only works along one ‘wire’ and won’t spread out in a circular pattern. I’ve experimented a little with Rope and Anchor Tags, but they seem to distort the spline way too much (although they might be good for making hedgehogs).
So, has anyone a way to make circular selections in Cheetah? Or a magnet tool for splines?
