Referenced Particles.js
Hello
it's a particle script to create particle(s) with specified position / rotation / scale of object(s).
update: 20160217 - rotation bug fixed.
update: 20170723 - add some options.
http://www.tres-graficos.jp/blog/files/article.php?id=105
Best
tg_jp, Hiroto.
Hi Hiroto,
Wow, that is a pretty cool script for placing particles individually. Thanks for creating it.:smile: :smile:
Bye
Hi Hiroto
Nice script, thanks for creating and sharing!
I'm wondering if it may be possible to add a parameter that allows you to rotate the individual referenced particles by rotating the 'reference object'?
Does that make sense?
Thanks in advance.
--Shift Studio.
pyramids vs spheres - right? so you can see what is going to point where.
Maybe a little x,y,z set of arrows would be even better.
I will try that.
--shift studio.
thanks Frank!
I will do that.
Still, a 'live' update would be nice - I suppose there are reasons that I didn't consider why it is done with a manual update though.
--shift studio.
lights don't travel with the referenced objects
There is an issue for me that when you reference an object which contains a light, the particles don't have the light with them.
Easier to see in my screen shots, and attached file.
This was tested using Cheetah3d v7.0b14.
Hopefully there a fix can be made at some point.
--shift studio.
  • RefParticles light issue.jas.zip
I thought lights&particles never worked together and might never will. Proof: put a light source into a Particle Array.
Yes, I suppose I knew that, but forgot.
I spent a lot of time trying to figure this one out. It didn't help that my referenced object was in another file and being accessed by a smart folder.
And that there was glass involved...
Anyways, seems geometry lights with emissive materials work as expected.
Thanks for clearing it up.
--shift studio.
