Moving in different directions
How do I move selected lines in different z direction, not the same way.
Hope you understand my problem when you see the picture.
1 separate the "claws" (or whatever they are) from the "arm" via the split tool
2 delete one of the claws
3 apply the symmetry modifier to the claw in the appropriate mirror plane
4 select the required edges on the "real" claw
5 transform as needed; in your case move on Z-axis
* the symmetrical "twin" will be subject to identical (but symmetrical) transformations
Servus from Vienna
SymmetryMod
Thanks for answering all :smile:
I use cheetah version 6, and in cheetah3d manual they use something called
"SymmetryMod" but I can't find it.
I have a bit problems with symmetry, used both Creator -> Symmetri and
Modifier -> Symmetry
I try to look in tutorials, because this is really basic.
I made it :O)
Thanks Helmut, now I have learnt something new, split tool :smile:
I think my problems with symmetri was because I didn't change under "Properties".
Sorry, I don´t know what you mean with "collapse".
If you want to make it invisible (all that is left are the claws of the head of the hammer), click on the M (=mode) tag and uncheck the "visible in editor" property.
If I have misunderstood the question, please elaborate.
Servus aus Wien
Two polygons
Sorry, maybe I used wrong word.
I mean, How do I make these 2 polygons objects to 1 polygon object.
Tack på förhand :smile:
1 turn the claws object into a child of the parent object (the head and handle mesh). To achieve that, simply drag the claws into the parent object inside the object browser panel (screen dump #1)
2 in the tools menu execute the command import children (screen dump #2)
3 this will "merge" the two separate meshes into a single object (it is the reverse of the split operation)
Note that:
4 the import command does not delete the child object automatically. You have to delete it manually (or save it into an invisible folder if you may need to fine-tune the geometry at a later stage)
5 importing children can stuff up materials you have applied to selections of the two objects. If you deliberately use different shading spaces for the two objects, materials are unaffected by a "merge".
Servus to Sverige
Post Scriptum
* It is not mandatory to import the children into the parent object.
* Any transform you apply to the parent object will "take along" any of the lower nodes in the hierarchy.
* Of course, this also works for animations, just in case you want to make a video of goose-stepping hammers :confused:
Servus from Wien
PPS: Sorry, this was a bit fuzzy / misleading:
* It is mandatory to set up the parent > child(ren) hierarchy
* It is not mandatory to import the child(ten) to create a single mesh :frown:
