Voxelate Script
Hi All,
just wanted to post this Polygon script I've been working on which converts objects into voxels (cube pixels). I've been using this for a few weeks now and seems quite stable but it can be slow with a large numbers of voxels and/or polygons in the underlying object. To get it to work place the object you want to voxelate as the first child of the Voxelate object.
Here is a quick run through of the parameters on the script:
Voxel Size: voxels are cubes this is the length/width/height
Origin: if origin is odd then a voxel is placed centred on origin, if even then the corners are placed on origin
Skin Tolerance: adjust what proportion (0-1) of voxel distance is detected as skin (fine tuning)
Skin Offset: adjust what position the skin is relative to actual polygons (-ve=inside, +ve=outside)
Y Truncate: trim top proportion of shape so you can see inside (useful for designing or fx)
Dissolve: remove a random proportion of the voxels (0-1)
Voxel Volume: proportion of voxel space filled by cube (0-1)
Cull Adjacent: if voxel volume is 1 then you can cull inside surfaces as you can't see them
Have fun and let me know any problems or queries,
Cheers, Tony
Hi All,
Cheers, Tony
