How can I set rotation value with normal Vec3D value?
Hello.
I am working with my new script, and I have problem unsolved with my skill.:(
I want to create polygon with rotation aligned to normal of other polygon.
I have already these values.
* normal Vec3D value of other polygon.
* each polygon info.
I tried to thise code...
// already getting normal for each polygon with normal();
var rot = new Vec3D(Math.atan2(normal.x,normal.z)*180/Math.PI,
                              Math.atan2(normal.y,normal.z)*180/Math.PI,
                              Math.atan2(normal.z,normal.x)*180/Math.PI);
var rot = new Mat4D(ROTATE,rot.x,rot.y,rot.z);
// and creating each polygon using rot.multiply([each vertices]) and addVertex();
so, how can I culculate these rotation values with normal Vec3D value?
I am so confusing with matrix and rotation culculation.
please, any advice.
Hiroto, tg_jp
still unsolved.
hi,
I had mistake before, totally.:(
this is new one, but it still does not work.
guideCore :-> from profile object
gVert :-> is center point of polygon i
var norm = guideCore.normal(i);
var nTrans = new Mat4D(TRANSLATE,gVert.x,gVert.y,gVert.z);
var nVert = nTrans.multiply(gVert);
var rx = Math.atan2(nVert.y,nVert.x);
var ry = Math.atan2(nVert.z,nVert.x);
var rz = Math.atan2(nVert.x,nVert.z);
rx = rx*180/Math.PI;
ry = ry*180/Math.PI;
rz = rz*180/Math.PI;
gRot = new Vec3D(rx,ry,rz);
// then I move each vertices by Mat4D(ROTATE, ...)
Hiroto, tg_jp
Hi Hiroto,
I haven't tired it but something like that should work:
var theta=Math.acos(nVert.y)*180/Math.PI;
var phi=atan2(nVert.z,nVert.x)*180/Math.PI;
var rot = new Mat4D(ROTATE, phi, theta,0);
test code.
Hello, Martin.
thanks for your hints, so kind.
but, I am still missing.
I try to post latest code for someone checking and testing code. actually, still not work correctly and not optimized yet.
test script:http://www.tres-graficos.jp/c3d/Polygon_Array.js.zip
Hiroto, tg_jp
  • Like
Reactions: DEO
Cool
Very nice script:D. Cool rabbit, how long did it take to render?
What are your computer specs? That many polygons would really slow it down.
Greg
hi, Greg
render time : MacMini (CoreDuo 1.66 + 2GB memory)
with Ambient Occulusion + HDRI : 6373.33 secs
without Ambient Occulusion : 32.73 secs
that scene is too heavy to manupulate objects in 3d view. but rendering time is not so slow.
scene info.
polygons: 1521392
triangles: 3042784
Hiroto, tg_jp
your rabit looks gorgeous. :D I will have a look into your script within the next days. Currently I'm a little bit out of time. But it looks like you are quite close to the solution.
