Z Channel?
2
Z Channel?
Can Cheetah 3d output in any image formats that can contain Z Channel information (RGBAZ)? If not, then can Cheetah render a grazyscale version of the image (based on object distance from the camera) which a compositing program can use as Z Channel information for an image?
Cheetah3d supports the .epx file format which contains a Z-Buffer. EPIX files can be opend with Piranesi but I'm not sure which other apps could open .epx files directly.
But .epx files are internally .tiff files. So if you change the prefix from .epx to .tiff you can open the file with a normal image processing app. The z-Buffer should appear in it's own layer.
P.S. For saving to .epx you have to switch on the "chache EPIX" property of the render preferences. This tells Cheetah3D not to reject the z-Buffer after rendering.
Hi, dexter0
I tried, but failed. I could open TIFF file that had extension changed from EPIX file. Graphic Converter showed three layers, first one is main image, but other two layers are just black image. Photoshop showed only one layer of main image without specific channels like z-buffer.
I'm missing some setting or tips?
I've only tried that trick with Preview.app. And it worked there.
Within Preview you can also save the depth layer separately to another file format. So you should be able to retrieve a grey scale image which could be loaded by every app.
It works with Preview!! thanks.
Hi Hiroto,
oh I was already sure that you want to try DOF. :D :D
It looks very nice. :D :D
Cheetah3D 3.3 will offer raytraced DOF which is physically correct but quite slow. But for a later update I also plan to add a post process DOF which is much faster and also looks correct for most scenes.
