BumpMapping not usable (?)
76
So - I have been trying to use Bump Maps to add "knurls" to a cap and to give a product label a hint of depth.
The problem is, the bump mapping is not working correctly. Note in the image I am referring to that the bump map correctly bumps "out" on the right side, but is inverted and sinks "in" on the opposite side of the object.
I have tried inverting the map so that black is white & white is black - all it does is swap the inconsistency.
I have bumped tolerances to no avail. Am I just out-of-luck using Bump Maps to simulate physical displacement...? I do NOT want to "model" all those knurls. Anyone have any insight into why this is happening. The only solution I can think of (which I have not tried yet) is to invert my bump map at its half-way mark... not sure what else to try.
-sf
Sorry - forgot to mention - This is version 4.2
I have not tried any Beta versions yet - not sure if they'll be any different.
Thanks.
Just tried one more test:
I inverted 1/2 of the bump-map to look like this:
( actual size is 2048 x 2048 )
And the result "fixes" the fact that the bump inverts across the surface, but adds a HEINOUS ridge where the invert happens:
I am stumped.
Frank - You seem very proficient with Cheetah. I wish there were a much more comprehensive "manual" that came with this app... but I know that $129 does not allow for such a luxury.
My background is with LightWave, but here at work, they did not have the budget for a high-end (expensive) app.
I am NOT familiar with this interface at ALL yet - I am just starting to learn it.
I have not figured-out yet how to bevel my extrusions, I have no idea how to use 80% of the tools in Cheetah (so far) but I hope to learn soon.
The techniques you used to make that red cap are very straightforward and make sense to me... IF I can find the right tools within the app.
I am an experienced 3-D guy who feels like a Newbie with this application. :)
Are YOU the guy selling a training video...? (DVD)
Im always keen to see cheetah related tutorials, So maybe you could email it to me too? I think you've already got my address...
Always appreciated Frank
AaronC
Hi Frank,
I sent you an email already, but yes could I get a copy of the tutorial, 1:1.
Much appreciated:) ,
Robert
Frank,
Thank you - I had NO IDEA about the ring select and ring cut tools. I really need to spend some time with this app, but have no time during the workday.
Thank you so much. Once I knew what those tools did/do... things got easier... now if I could only learn the OTHER few-dozen tools. :eek:)
-sf
I've just fixed the bump mapping bug. It will work in the final 4.3.
