-- material and render
Hi to all again,
I'd like to understand better how to change the properties of material to create a "chrome-like" metal material and a "porcelain-like" material.
What about the different "reflection/specular" angles viewed by the camera in rendering?
here you can find what I mean:
http://content.luxology.com/modo/201/video/renderProject.mov
I make a simple scene (not so beatiful and refined as in the tutorial above
..but to understand is ok...) and I add the different material to all the object.
The material is the standard (I don't change anything), so you can change everything to have a similar result.
I try to make something similar (add emission to the 2 light panel, changing the property of specular/reflection and ambient of material, add radiosity ambient occlusion/radiosity, switch off camera light, add other area light on top....) but I can't make realize the porcelain and chrome as in (similar) the tutorial above.
COULD YOU HELP ME and try to make it for me? (simply change the material property/camera property/ light property)
Hi to all again,
