uq6 (Offline)
Default Empty boolean union - 28.01.2017, 23:49
I've really been enjoying the upgraded booleans in v7. However, I'm running into an issue (in both b19 and b20).
The attached .jas file shows an empty union. But turning off the creator tags shows the original geometries aren't empty.
Thanks for any help.
Default 29.01.2017, 00:19
This won´t work because of its intersecting geometry.
I´d skip the bevel/chamfer - make the 2 keys editable - select front and back polygons - make inner extrude and pull out for a nice bevel.
Align everything to your liking and boolean will work as expected: file attached.
When you use ->Polygon->Boolean instead of modifier/creator add it will maintain material assignments BTW.
Both extrude objects are labeled "watertight" - but it won´t help with Boolean operations in this case.
(You introduced some scaling issues too - but I don´t think it´s the problem here.
Life is short. Eat dessert first.
Swizl (Offline)
Swizl's Avatar
Default Background Image Color Change - 30.01.2017, 19:24
Anybody know why C3d is changing the color on a background image? The original image has a lot more saturated wall color. I used the Cheetah Renderer on this one with HDRI. I didn't think any of the render settings would effect a background image though. ?
Last edited by Swizl : 01.02.2017 at 14:07. Reason: Changed out image for iStock image with watermark.
Jeanny (Offline)
Default Change Color Tint Caused By HDRI - 30.01.2017, 20:13
Hi Swizl
I don't know if this will help you any. Last week I was trying to render a white image. I was using the “oldtown_pano_sm” image for a HDRI.
The image kept rendering blue instead of white.
By trial/error and accidents i was finally able to achieve my goal.
I made lots of notes.
I've included a pdf in this post.
My Best
Jeanny
Swizl (Offline)
Swizl's Avatar
Default 30.01.2017, 20:16
Originally Posted by Jeanny View Post
Hi Swizl
I've included a pdf in this post & I'll post again with two more pdf's.
My Best
Jeanny
Thanks for responding. I'll check it out. I'll have to test it in v6 and see what it does. Not good though IMHO to have the background image change color.
Jeanny (Offline)
Default 30.01.2017, 21:08
Sounds like a necessary heads up. What is an IMHO?
Maybe I should find another avenue my self.
I don't want to run into problems down the line.
My Best
Jeanny
bobziila (Offline)
Default 30.01.2017, 21:15
IMHO = In My Humble Opinion
Bob
Swizl (Offline)
Swizl's Avatar
Default 30.01.2017, 21:17
My Best
Jeanny
My solution was to set up the scene with the image in the background. Then I rendered the scene with only the 3d stuff and a transparent background. I saved the image as a png. Then I composited them in Photoshop. Paste in Place makes it easy when the resolution is the same for both images.
Default 30.01.2017, 21:27
Once again in slowmo: In essence you´re saying with just the appearance of the the poster on the wall the tint of the whole room is changing? I doubt that.
Swizl (Offline)
Swizl's Avatar
Default 30.01.2017, 21:36
It's changing even when there isn't anything else in the scene. Can you see the two images I posted next to each other? The first image has nothing to do with C3d. It came from iStock. The only thing I did here was reduce the size so I could post it. So there still should be an explanation of why C3d is changing the color so drastically?
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
