uncle808us (Offline)
uncle808us's Avatar
Default Normal map setting - 05.09.2018, 00:45
I know how the bum map numbers at the very bottom work for setting the intensity of the height map. But do they have any effect on a normal map is it proper to just let them at zero?
MacBook Pro Retina, Mid 2012 15 in. OS X 10.11.6
Default 05.09.2018, 09:16
As for all other node connections; when connected the value/number will be overwritten by the connected node. I believe the entry field at the bump channel is a special case and just there for continuity but numbers didnīt work at any time ever since. You need some "multiplyadding" or "intensifying" (Texture-node) of the image to control the bumpiness.
Life is short. Eat dessert first.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
