Boolean trouble
Boolean trouble
i mean why i can't use this creator with those objects. One is simply plane and another created from spline
  • test.jas.zip
Make the extrusion editable and optimise. Seems to work properly after that. Maybe some fishy topology which bamboozles the late George Boole :tongue:
PS:
* If you check the object analysis prior and after the optimisation you will notice a slight reduction in the numbers. I could not see any obvious mess, but I only briefly checked the geometry.
It's for the better bending (after objects intersection). But it's really not the problem for this case.
It won´t help with the depth section. You need more geometry there as well; see image.
* You may also consider a modular approach.
* In my trivial example I use a hexagonal tube, the outer perimeter of which is tweaked into a rectangle. This is modified by a standard array.
* The panel is just a plane plus some minor fiddles plus a shell.
* Your object seems to be symmetrical on two axes, so you just need to model one quarter.
* I have left some gaps to show the individual elements. Of course, I have no idea of your aims, so this may be totally useless.
But i see no problem with this example
  • test2.jas.zip
Seems your spline was the sucker in first place. The one I created from scratch worked as expected:
