Cheetah3D 5.7 Beta 2
#41
Nice work Martin! (as always)
Nice work ebstudioslive! (the black spots on the dog don't work well with the black background but the overall composition is nice)
#43
Mouse Rotate Issue with Large Scale Models
Hi Martin,
I am still working on those tubes!
When I have a model and the tubes are at a large scale, the control keys are quite jerky.
Please see attached file. Try to rotate the mouse around an object and I think you'll see what I mean. It makes it very difficult to achieve precision.
Thanks for taking a look.
--MarkE
#45
Control Keys
The ones from the preferences for One button mouse:
ALT + Mouse Drag:
Rotate camera around object.
ALT +  + Mouse Drag:
Zoom camera.
ALT + CTRL + Mouse Drag:
Move camera.
I figured out that the camera is rotating around a pivot somewhere deep in the Z space (I have no idea how it got set that way, or how to set it to a new center). I saved the file under a different name and it now longer exhibits that behavior.
frank beckmann
#46
When in object mode click to select your main object of interest and then the little icon in the upper right side above 3d-view called "focus camera" (better set as a hotkey) - that will bring you instantly to the object and camera/perspectiv view will rotate around the "focussed" object.
3D View Camera Guidelines rendering in reflections
Okay, see if this one confounds you.
I changed the 3D View Camera Guidelines in the preferences so I could better see the camera frame. The guides are rendering as reflections in my objects. See the red in the attached jpg. I tried to turn it off by making the guides 100% transparent. No good.
I notice changing the Camera color does something similar. Martin, can these be made visible in the editor and invisible in render?
--MarkE
Thank you Frank, perfect.
frank beckmann
#49
That seems a redraw bug in the camera background color option when the opacity is turned to 0%.
I started a new camera and it´s gone. Martin has to check it up. I sent a report.
Thanks for testing the beta.
#50
Odd repositioning of objects on Save
In beta 2 I am importing a PDF profile to use in the Lathe creator object to make a tube. Before importing I save my file, then import the PDF. Immediately after import, several of my objects have moved to a different position. See images.
If I close the file without saving and reopen it, the objects are still in the (new) wrong position.
If I open the file in 5.6, the objects are in the correct position.
--MarkE
frank beckmann
#53
Well - yes I can see it. But again I can´t recreate it. I wonder why your pdf is 204KB for a simple path what needs maybe 4KB all the most. Have you checked you pdf-import properties at the preferences? Should set at "0.01".
Seems I ran out of suggestions.
(Maybe put it all together and send it over to Martin)
uncle808us
#54
Import children Bug
I drag the child onto the parent.
I have the import children assigned to the (i) key I press it and the tool shows up but when I double click the parent icon the child is deleted.
If I do the same thing but use the drop down menu item import children it works as expected. Is this a bug?
http://blip.tv/file/4948412
