Set Smooth Angle Globally / Global Iterator
This script lets you set the smoothing angle of every editable polygon object in a scene with one click. Very useful for rendering files imported from parametric modelers such as MoI 3D, Rhino, etc.
Biggest hassle -- figuring out that the parameter for controlling smoothing angle was named normalAngle!
The script is loosely based on Martin's "Scale Light Intensity" script, but demonstrates the use of first-class functions and closures to allow very simple creation of global iterators.
Code:
function buildUI(tool){
    tool.addParameterSeparator("Set Smooth Angle");
    tool.addParameterFloat("Angle",15.0,0.0,90.0,true,true);
    tool.addParameterButton("Set Smooth Angle","OK","set_smooth");
function set_smooth(tool){
    var doc = tool.document();
    var angle = tool.getParameter("Angle");
// here we create a function which will be run on every object in the scene
	var fn = function( obj ){
		if( obj.type() == POLYGONOBJ ){
// note that we're using the LOCAL variable angle, which is stored in
// the function as a closure (don't worry, it "just works")
			obj.setParameter("normalAngle", angle);
// we could call it on document.selectedNode() instead, but it would then be
// really hard to do the whole scene
    iterateTree(doc.root(), fn);
// iterateTree applies fn to every obj in the entire scene -- how slick is that?
function iterateTree(obj, fn){
	fn( obj );
    for( var i=0; i<obj.childCount(); i++ ){
		iterateTree( obj.childAtIndex(i), fn );
This is a tool script.
(So it goes in ~/Library/Application Support/Cheetah3D/scripts/tool, and after you install it and restart C3D it will be in Tools > Script > Tool > Global Iterator.js )
The basic idea is that to add an iterator you simple create a function and pass it to the iterator along with the root node.
  • Global Iterator.js.zip
