UV Stepper.js - move, rotate, or scale UV coordinates with certain values
this script is a Tool script for moving, rotating, or scaling UV coordinates of selected polygons with certain value. and you can move selected UV map to left/center/right position in UV field.
download -> http://www.tres-graficos.jp/blog/files/article.php?id=32
Updated: fixed alignment (center/middle) bug and now work Point and Edge mode. 20080217
Updated: fixed bug when using with version 4.6. 20080528
Updated: support uv1/uv2 copy and swap. now support uv of uv2 set correctly. (only 4.6 later) 20080716
Updated: 'weld', 'invert' added 20081216
Updated: object uv copy added. a behavior of collection for current selection changed. (when nothing is selected, script affects all uv info of object.)
Updated: 'select UVPIN in selection' / 'align circle' / 'move to' for set absolute position functions. update recommended. 20090619
Updated: fix bug with cheetah3d 5.2 20100125
Updated: add getAngle / getFitScale 20110411
regards.
tg_jp, Hiroto.
regards.
tg_jp, Hiroto.
