Scalpel Tool -- Cutting a Hole in a Face
Tutorial answering question posed in general.
No, it IMPLIES that you use the scalpel tool but it doesn't actually SAY it.
You could just as easily Ring Cut the mesh or something similar.
Apart from the title it doesn't mention the scalpel tool at all so implication is all we're left with. You could ring cut but then you're adding additional polygons you don't need.
How do I make the Extrusion into a hole?
Thank you for the nice tutorial. After the last step, I got a nice round black cylinder as shown in the attachment. How do I make it into a hole?
Thanks!
Jerry
Hi Jerry and welcome.
Either you can pull the selected/extruded polygon into your object, or if you want a hole that´s going through the box, make sure you make the same steps (at the same time) on the front&back side of the box. After the last call of Cattmull Clark delete he polygons and use the bridge tool to build a channel from front to back.
Whoa. I'm not that smart yet. I did not know how to "pull", so I started over and did this...
1. Objects ► Polygon ► Box
2. Adjust to desired thickness, but the plane containing the hole must remain square if you want a round hole.
3. Objects ► Make Editable
4. Switch to Polygon Mode
5. Selection Tool
6. Select a face (turns pink)
7. Tools ► Inner Extrude
Click on face. Extrusion appears
8. Click on face again and again to make smaller extrusions, until you get the size you want. Remember that Catmull-Clark will make it smaller still.
Question 1. Is there a more precise way to do that? What if I need a hole that is exactly a certain size?
9. Tools ► Catmull-Clark Subdivide, several times.
10. Tools ► Extrude. Drag left until it goes all the way through.
Question 2. Is there a more precise way to do that. When you get to the end it quickly turns different colors and I'm not sure where to stop with the mouse.
11. Change to polygon mode.
Change view to look at the bottom of the hole, which is black.
12. Use the Select Tool and select it.
13. Hit the 'delete' key. The hole turns from black to gray, and now you see the lines between the Catmull-Clark subdivisions which were not there before.
14. Click on one of the subdivisions, and drag over the remainder so they all become selected (turn pink).
15. Hit the 'delete' key again. Now, the hole is all clear.
Question 3. I'd like to understand what this "extrusion" is. It does not show in the object browser. What, exactly, is it? Apparently it is actually two things: The thing(s) that got deleted when I hit the 'delete' key the first time, and the thing(s) that got deleted when I hit the 'delete' key the second time. What are these things?
It looks like this is not necessary with the method I used. I believe the purpose of this step is to build an inner wall around the hole, but that seems to be already present.
The attachments here show the results up to step 10.
Hi Jerry.
Can I send you a small video on this, maybe 2 or 3 MB of weight?
I don´t think I can compress it small enough to be accepted by the forum´s software.
Edit: if I read correctly you mixed up 2 things. Going for a complete hole, make sure to delete the tesselated polygons on the front and back side. Now use the "bridge tool" by clicking/selecting 1 point of the edge around the hole on the back and 1 (opposite) point of the edge around the hole on the front side-voilá - there should now apear the pipe.
Final Result
The following attachments show the final result after completing steps 11-15.
Can anyone answer the questions 1-3 in my previous message?
Thanks for the help,
Jerry
Hi Jerry.
Sorry, Frank. Looks like I missed this reply because I didn't notice that the thread had continued onto page 2. But, yes, please send the video. 2-3 MB will probably make it through email if that's what you want to do.
Jerry
