PVC Pipe Fittings
5,714
I like to find things around my house to model, and keeping with the
manifold pipe thing, I found a Drain Waste Vent fitting in the basement.
Building a pipe manifold can be quite problematic at times, but this one wasn't to bad.
I used FreeCad to build it and Cheetah to radius some edges and make the cutaway.
Here's a screenshot of the model in FreeCad. 3"x 3"x 2"
I Rendered these with the Falcon renderer, saved in 32bit at 7680 x 4320 resolution.
Tone mapped to 8 bits and reduced to 3840 x 2160. This is the actual
resolution of my monitor when it's set to 1920 x 1080.
This one is a Sanitary Tee. It's sized for 3" pipe
which is measured by it's inside diameter.
For some reason this one was hard and I had to try a few times
to get it to work, but now Cheetah won't let me Boolean it in half.
I may have to do the cutaway in FreeCad.
No 32bit treatment for this one.
