- Messages
- 5,635
When working with imported OBJ or STL files in Cheetah,
you can't use tools like Loop Select, Ring Cut or Ring
Select because of the triangular polygon construction.
Here's a trick I figured out if you want to steal
some geometry from a model like that.
I built this in FreeCAD and exported it in OBJ format.
Here's the model in Cheetah 3D. Rendered with the Falcon renderer, Smooth Angle 30.
What if I want to utilize the outer contour as shown by the black line in the image below?
I could recreate it with a Spline. But what if it was much more complex?
This is how the "wires" look.
