Mirror Copy.js
tg_jp
Mirror Copy.js
Hello,
this is Tool script for copying object symmetrically. for character bones.;)
this works for v4.0+.
please check sample movie.
sample movie (h.264 8.8Mb):http://homepage.mac.com/camelio/ch_movies/ch_20070324_mirrorCopySM.mov
UPDATED: now you can copy polygon objects.
UPDATED: fixed polygon object copying bug. 2008-06-06
download->http://www.tres-graficos.jp/blog/files/article.php?id=25
UPDATED: fixed bug for 5.0. 2009-10-14
UPDATED: fixed bug for 5.2. 2010-01-21
download for 5.x -> http://www.tres-graficos.jp/blog/files/article.php?id=51
tg_jp, Hiroto.
tg_jp
hi,
Heh -- I just *did* ask and was referred to this script. Does it mirror constraints?
yes. this script copy all tags ( Constraints, Handle ) with parameters.
but testing may not be enough. so if there is a bug after your testing, please let me know it.
regards.
tg_jp, Hiroto.
podperson
I can't currently use this script. I installed it and it doesn't shop up. I tried an older version I had lying around and had the same problem? Am I screwing up something or is there an incompatibility with 4.3.1?
frank beckmann
Mmmh - works just fine here.(Tiger/Cheetah4.3.1)
Are you sure storing it at: Harddisk/User/Username/Library/Application Support/Cheetah3D/scripts/Tool/ ?
tg_jp
hi,
> podperson
thank you for trying this script. I checked it with Cheetah3D 4.3.1, it worked with my Mac. so, I don't know why it doesn't. any alert?
* doubleclick a file Mirror Copy.js_20070730.zip to extract it.
* place it ('Mirror Copy.js') into ~/Library/Application Support/Cheetah3D/scripts/Tool folder
* relaunch document and select 'Mirror Copy.js' from 'Tool -> Script -> Tool Script' menu.
please make sure that script file name is 'Mirror Copy.js'. '.js' extension is required for script file.
regards.
tg_jp, Hiroto.
cnitteberg
New member
I use leopard(10.5.1) and I had to put it in:
Harddisk/Applications/Cheetah3D/scripts/Tool/
where all de other scripts are.
If you doesn`t find it just search for one of the other scripts that come with Cheetah3D with spotlight!
tg_jp
update for bug fix
hello.
I updated this script. I fixed a bug that mirror copying of polygon objects caused error with version 4.6.
if you use it, please replace it.
regards
tg_jp, Hiroto
podperson
I'm having a lot of trouble with the copy/paste parameters function -- it produces twisted results. I don't think I had this problem before.
I modified the script to replace "L-" at the beginning of an object name with "R-" (vs. "..._copy" so "L-thigh" becomes "R-thigh") but as far as I can tell your code doesn't rely on names, so I think that the order of children in the copies has changed vs. v4.0 (the problem seems to occur if the hierarchy branches, but it sometimes occurs elsewhere).
tg_jp
hi,
thank you for reporting. but I cannot reproduce it, it occurs that problem with all mirror plane (x/y/z) or certain plane?
if it available, please post the file.
I already updated the script to fix parameter copy/paste bug, and add pivot copy/paste for v.5.0. if you not yet, please update it. ( few line added, so you can easily modified your customized one. I will add name conversion function for next update. ;) ).
regards.
tg_jp, Hiroto.
podperson
I was using the latest version on the website as of two days ago. I'll see if I can dependably replicate it and post the file.
podperson
I think my file had some kind of internal corruption in it (the unique id issue again) because I ran into a bunch of problems while trying to move things around inside the hierarchy. So maybe the problem is just me.
I did come across this error though (note that the right hand has a gun in it while the left does not, which means the hierarchy is not perfectly symmetric).
