Quick Look & C3D
* @uncle808us
* Only recently, you asked about the Quick Look option in conjunction with .jas files. Frank, at that time, pointed out that this was not possible.
* This is perfectly correct, BUT:
* macOS can handle .stl / stereolithographic documents without a problem for ad hoc pop ups. They also can be rotated (+ inertia) / zoomed / ... The same applies to .obj documents, where you get additional colo(u)r information.
:mad: It is a bit slow, shows objects which are hidden in the jas browser, switches axes and the file sizes are quite significant...
:whistle: You may consider saving specific models in .stl format if it suits your work flow and your HW.
* Quick Look of our Romanesque / Gothic cathedral, somewhat modified.
Thanks this is good info.
