GS089
Member
I will use a thickness of 3mm, that is pretty standard. One plate is around 2x3m if u buy them at a big wood shop, they can cut it down to the size the laser cutter can handle, but that size I have to check when everthing is ready. A common size would be 60x80cm.What are the standard plywood thicknesses in Germany?
I'm wondering if the thin vertical fin could be one piece of plywood.
If so some of the UVs are not needed.
If I make that fin of solid plywood it would be very heavy what I want to avoid under any circumstances (for structural reasons and reasons like transport or mounting) and it would bend over time, maybe.
If that thin fin is only 10mm, it should be made at least 16mm (2x3mm hdf + 10mm carbon rod). I thought you said earlier it has a thickness of somehing like 2,25cm.
