GS089
Member
Yes, tolarances of a few 0.Xcm are only important when I am doing the teeth for the joining of the 3mm hdf plates, a difference of 0,2mm is the difference of loose or dont fit. But that, I will do in illustrator and I have to talk about that with the cutting service. If the whole sculpture is 291cm or 289cm is not a big problem. 291cm is just the result of the measurment of a picture of the original painting, if the overall painting is really 400cm. The time I stand in front of the original I didnt had a folding rule with me... I could spoken to the museum where it is presented, but a few mm or even cm difference are ok, it's important the the uv of the element fit in itself to build that element.
At the end, it should stand in front of the painting, thats why it should be the same lenght as the original.
Gerald
Edit:
If only one element is to big, like 2-3cm, it would change the relation to the other elements, and that would be seen clearly... but other than that...
Edit2: Another thing is the mechanical aspect, one of the verticals, where all of the horizontals a mounted will be a little bit thicker, but it will be clearly the thinniest of the three vertical elements... it should be a little bit thicker to have to possibility to strengthen it from the inside with some carbon rods... but that I have to test when its stand in front of me...
Gerald
Edit:
