GS089
Member
I think to build the curved elements seperately would be great, and it should be no problem to strengthen the main element where the parts should be mounted. Building the elements with ribs is final, that should work best. Seeing the elements combined and the legs attached in one piece of hdf makes me worried about the material that has to used. There will be a lot of material wasted and having hundreds of ribs means hundreds of smaller hdf plates… which will be very expensive… :/
The workflow of Eric in #280 is the way i have in mind…
Perhaps I should just start building the first part of the curved elements, the part without the intersecting elements… then I can test the workflow, the weight, the stability and the finish. Just the first curved element… That would be a nice and interesting start.
