When I was a young boy my father built just such a device using a model trainAddendum:
* Styrofoam can be cut easily with a hot wire stretched between two fixed anchors. The gadget looks a bit like a copying saw with the saw replaced by a wire. The wire itself is heated via a transformer which plugs into the mains.
* Simply draw the shape of the rib onto a thinnish cardboard, cut that out with a Stanley knife and pin this template on top of the foam sheets. The hot wire just melts its way through the foam panels.
* Warning: a minimum of skill is required here. Work smoothly and do not stop, as the heat may overheat the foam and it starts to liquify and even burn!
transformer, a wooden board, a bent windshield wiper and Nichrome wire.
"Bondo: It works well on wood, foam, and carbon fiber.
For modeling purposes, Bondo's density lets it stick well to pieces of wood, foam, and carbon fiber."
