GS089
Member
I am searching for an easy to use 3D program and I got to the hint to have a look on cheetah3d. So I used the demo for a few minutes and it looks really promising.
Maybe I have some more questions, and if I choose Cheetah I will watch some tutorials, but for now I have these questions.
1. Is it possible to export a single faces of our object? Maybe even all at once? That object contains only of a few simple geometric objects like a rectangular. So after building my sculpture I want to export the each faces/plates that I can lasercut from 3mm hdf wood and build that sculpture. I hope that make sense..
2. Is it possible to transform a object not only in its three axis, Would like to transform it on a round axis.. so I build an object with a lot of rectangular shapes.. and then I want to select all and make a loop of it.
Thanks a lot
Gerald
P.S.: All is to to construct a scultpure I want to cut 3mm hdf wood.
Thanks a lot
Gerald
