This is a model of an SLIBB Clothes Pin that I saw on line for the first time today.
I liked the way this object looked so I thought it would be great project.
I can animate the body of the clothes pin with a simple rotation with three keyframes.
The spring is a Spline/Sweep so I have to manually keyframe 30 frames to match the body motion.
Here's 9 frames of 60 from a 2 second clip.
I'm not loving the way the spring thing moves.
It's not bad but I was hoping it would look better.
Instead of redoing the 30 keyframes of the spline
animation I'll make another version of the
spring thing with Bend Modifiers.
Apparently these clothes pins are designed to open further than the common
wooden clothes pins in order to accommodate thicker materials like knitted stuff.
Since the jaws are not parallel as soon as you open the clothes pin,
I thought of a design change that might give a more gentle "pinch".
