I'm going to attempt to make a multipart tutorial as I build a custom bicycle frame.
Depending on your needs, it starts as simply as finding or taking a picture of a bicycle.
It can also be extremely complex as there are so many things to consider.
If you're going to take the pic yourself, try to use a telephoto lens from the
side and get as far away as possible to reduce any perspective distortion.
The image I'm using is a rendering of a 3D model built and rendered by
Robert Biehle https://grabcad.com/robert.biehle-1
Pictures and free models can be had at GRABCAD: grabcad.com/robert.biehle-1
Built in Solidworks.
I have not downloaded his models yet, and there isn't a lot of
his work out there that I can find, but he is clearly into bicycles.
If you want to see all the pictures of this frame at different angles
look here: grabcad.com/library/custom-carbon-road-bike-frame-1
1 Cheetah unit = 1 inch
27.5 inch wheels
You can use the this jas file as a starting point for a road bike, but the next one I post will be altered to be the Track bike I'm going to build.
27.5 inch wheels
