Just opened Alien Walk sample, and I get the same thing. The objects are there in the object viewer panel, and both stills and animations render just fine, but the modeling viewport is blank...Strange. It is compatible with BigSur and runs on M1 as well in Rosetta2. Have you tried any example files already?
If C3D is launched with my iPad Pro connected via Sidecar as a 2nd display (which it always is), then the issue occurs.
Shotster,
I have no idea of the root cause of the issue and have not experience the issue - But, perhaps the following might work and reset the viewport...
1) Right click the "3D View" tab and select "Delete View" - screenshot 1 below...
2) Then Right click in and empty spot in the tab bar area and select "Add Tab" - screenshot 2....
3) Then Right click the new tab and select "3D View" - screenshot 3.
I'm guessing this fix attempt probably won't work, but it's worth a try.
View attachment 37782View attachment 37783View attachment 37784
Shotster,
