There are a stack of matters you can look at:
* Masonry:
* The texture of the brickwork on the corners (of the building / to openings) is clearly incorrect. Applying a pattern to geometry so that it fits at edges is not so trivial.
* The bricky pattern must fit the dimensions (X & Z, any horizontal length between ends) of the wall. Zooming in on your image shows that you start at many edges with tiny slivers of a brick which won´t survive.
* I have no idea if the ground floor is full brick or masonry veneer. The bond implies full brick. In any case, if masonry veneer. you need to show weep holes at the bottom of the external walls.
* I am also suspicious of the brick size you are showing. These are certainly not standard sizes and this may complicate the maths of fitting textures to topology.
* Timber Cladding:
* Normally, these are just horizontal boards, which are slightly angled for overlapping. No doubt there exist more expensive grooved / tongued cladding strips.
* Attic & dormers:
* A glimpse of the interior of the upper level indicates that the roof construction is paper-thin. This should to be 30cm minimum (rafters plus insulation plus air space). As you are using monk & nun tiles of a dark colour you are already heating up the attic. Depending on the location of the cottage this may make sense or be a waste of energy unless an
upstairs sauna is envisaged.
* There needs to be a flashing, generally galvanised steel, at the bottom edge of the sidewalls of the dormer. Otherwise precipitation just seeps in. The same applies to the edges of the roof. In the case of the roofing tiles you have chosen this may require concave tiles at relevant edges.
* Reflections:
* There is an inconsistency in the reflected outside natural environment. In one window I observe some grass and foliage in the distance, in others I see a flat plane to the horizon.
* Windows Transparency:
* This shows objects which I can not interpret. There are greyish frames visible which are a mystery.
* 3x3 openings
* These may possibly be French windows, consisting of a 2x3 door and a 1x3 side panel. If so, the frames should show the two panels, possibly even by rotating one of the panels to show an open leaf.
