Do you really want all windows modelled? Just asking.
Thank you so much for the reply Helmut, and wow, amazing what you guys can do just to reply on a post, really appreciated. Also, I have not seen that thesis, and I cant believe you found it?! Same with Franks findings of the blueprints, I cant thank you enough. Now, when it comes to the issue of using these blueprints, and by only learning one technique which was creating one box then "inner extrude" and "extrude" for shaping length, width, height, roofs and windows. I also learned some information about UV mapping, and I am pretty familiar with Photoshop, so I go the basic gist of how to work with textures and UB (except i forgot how to scale textures with transform tool in c3d). The usage of particle mesh I have not yet experienced, it only shows up as a blank canvas which i cant find a way to control or respond. Under I will post a more updated post on how I am doing with my building. Edit: I just now searched for particle mesh on this forum and found yours on "spiral case for newbies", I will look into posts like these, if there are any more posts like this that you can think of on top of your head I would appreciate it. Seeing as the post that supposedly contains a mash of tutorials are really outdated.* Oslo Rådhus is a prime example of repetition in architecture (and of instancing in 3D modelling). Basically there are 4 intersecting cuboid building blocks with holes. Such holes are covered by a small set of identical panels.
* Once you have determined the grid used by the architects in the X, Y and Z axes you just generate and poulate a particle mesh by numbers, where a number is a placeholder for a type of cladding panel.
* In my simplified sample I used 5 different panels. I estimate that 12 should suffice for the entire building.
* Extensive refs, eg Schøning, Trond L.: Det norske hus (PDF), hovedoppgave i kunsthistorie, UiB 2001 are available. I am sure you are aware of this publication.
* It is mentioned that the architects used bricks slightly larger than the standard of the 1930s. Clearly, the brick sizes must fit the grid size used. You need a precise mesh of the offsets at the edges for a clean tiling.
