Exporting textured planet to .obj file
I created a sphere, then converted into a polygon and then textured it with the "Planet" material. The resulting model rendered beautifully, so I baked the texture and saved it into a file named Planet.png. I then exported the model to .obj format to get a Planet.obj and Planet.mtl file. However, upon inspecting the .mtl file, I found it contained no reference to the generated texture map file Planet.png. What do I need to do to get the export to link the .mtl file to the .png file?
For reference, I've attached copies of the various files in a .zip file except that i had to derez the Planet.png file into a Planet.jpg file to get the size of the zip file down to something this system allow me to upload.
Wayne
Hi Wayne.
I guess you baked the texture to UV set 2 instead of default UV1.
Bake again (add an ambient light source) save to png - make new material add png to diffuse channel and assign to "Ball" (delete former material and Bake-tag assignment - export again.
Oh, BTW, is there some way to alter the appearance of the planet, such as changing a random seed? Ideally, it would ne nice to be able to define things such as the ration between water and land, or water, land and snow.
Wayne
#7
Thanks again! I'd forgotten about the node interface, as I've never really learned to use it. I'll have to remedy that. But, I like that I can change the turbulence value independently from the fractal value, as that would seem to allow me to generate the same planet with different weather. Is that right?
Wayne
#8
Sadly not, turbulence and fractal together drive the whole gradient including the white cloud like parts.
With this linear setting landscape and clouds cannot be adjusted independently, that would afford a more sophisticated node setting with independent node chains for ground and atmosphere.
