Human Circulatory System Model
I still need to add the vessels and nerves but
I wanted to see how a Boolean cutaway would look.
While making the veins I found some interesting behavior
with compound paths and the sweep rotation property.
I didn't want perfectly circular tubes, but something more realistic
like a flattened ovoid shape with some rotation along the length.
I started with a compound spline and animated the Sweep rotation property.
The center spline section rotates differently from the outer spline and the end-caps come unglued.
Then I used a Shell modifier to get it to work.
This one has the ovoid shape and Subdivision Modifier to get a rounded look at the cut ends.
While the compound path Sweep seems a bug to me not updating cover correctly while rotating the shelled sweep works just so lala when the spline has iterations:
Very interesting. Did you notice what the other end of the inner spline does?
It seems to oscillate in opposition.
I wonder if that changes if I move to center point of the line spline?
In terms of modelling this seems a "serious" bug:
I know I can make a mesh and use the Twist-modifier but I prefer not to do so.
Here's the collection of splines for the leg so far.
I finished the veins, now I just need to add a few arteries and nerves.
So all parts are created with these splines individually or in combination
using sweeps, extrusions and for the cutout, Boolean subtraction.
I know. ;) But:
And I still have a slightly issue in terms of consistency when putting a text spline and a spline object Z-axis oriented in a sweep-creator it will appear reversed. I know I can rotate the spline 180° but how to explain to a newbie why it is when the extrude-creator makes it readable by default. :unsure:
Two examples of what needs to be improved.
The backwards thing is annoying because it just seems wrong.
I can't figure out a good reason for it to be that way.
I noticed in the gif you posted, if you move the text
spline below the line spline it clears that problem up.
