Can't undo keyframe pasting
I've noticed that ⌘ + Z doesn't work for the pasting of keyframes. Pasting keyframes potentially overwrites keyframes at the same location and thus is a destructive operation.
• create a cube
• open "key" panel
• record key at time 0
• record key at time 1
• go back to time 0 and move cube to a different position
• record key again (at time 0).
• go to time 1
• drag-select the keyframes at time 0
• press ⌘ + C and then ⌘ + V
• press ⌘ +Z
• there's no animation between first and second cube position when pressing play
expected: there should be an animation for the cube between time 0 and 1 because we pressed undo after the operation that made the time 1 keyframes the same as time 0.
