SCRIPTS: A Quick Guide
Joel
#22
Controlled Spline
This is a powerful tool for adjusting control points in a spline. It is super precise, easy to fine-tune, and best of all, it’s intuitive — you place objects as proxies for the spline’s control points. Manipulating 3D objects is simpler than tweaking points in a complex spline.
Notice that there are two scripts, including the Tag.
Thanks to Hiroto.
Thread for the file:
https://www.cheetah3d.com/forum/index.php?threads/9251/
Thread for a tutorial and tips:
https://www.cheetah3d.com/forum/index.php?threads/12113/
Joel
#23
Camera Mask
One simple feature that I wish was integrated into C3D is area render, to only render a selected detail while leaving the surrounding render intact. When fine tuning a complex scene it can take a long time to do a high-resolution test render. Typically, this render time is multipled by the number of test renders done as part of the trial-and-error process. Depending on your choice of Cheetah or Falcon renderer, your computer’s speed, and your patience, this may not be an issue. If you are only tweaking a single detail the Camera Mask is an instant solution for a test render. Click its visibility on or off as needed, and just render the “window” surrounded by a solid opaque color. It would be better to have an option to leave the surrounding render as-is, but this is still a potential time saver.
Thanks to Hiroto:
http://www.tres-graficos.jp/blog/files/search.php?k=camera+mask&d=&p=0&c=0&pn=1&f=
Joel
#24
Illustrator Import
This last script isn’t one I have really made much use of, compared to the others, but I include it in case any of you might need it. From my limited experience, it seemed to be an essential link between Illustrator files and C3D.
Some of you are adept at Illustrator and readily create paths for use as C3D splines. I have recently done some experiments with the Inkscape vector drawing program, but 99% of my computer graphics use either C3D or vintage 2011 Photoshop. Three years ago I used a picture for a reference and for an Image node material for C3D. I made some paths in Photoshop and exported them as Illustrator files. The Illustrator Import script was necessary to import them into C3D. There may be a better way to do this, as the process I devised was complicated and glitchy. If there is any demand for them, I can post four pictures that document how it worked, but I invite anyone reading this to post a simpler approach, a step-by-step illustrated tutorial, preferably using free programs such as Inkscape or Open Office. The script dates from 2006, and I used it on C3D 6.3. I haven’t tried it on Version 7, but all the old scripts I have tried have worked, so backwards compatibility seems to be a Javascript virtue.
Thanks to Hiroto:
http://www.tres-graficos.jp/blog/files/search.php?k=illustrator&d=&p=0&c=0&pn=1&f=
#25
* Arrows
* Various types of arrows.
* Splines #1
* Various simple splines. Generally, names are self-explanatory.
* Splines #2
* More simple splines. Generally, names are self-explanatory.
* Splines #3
* And even more of the same. Generally, names are self-explanatory.
* Spline Grid
* Generates a 2D / 3D grid.
* Sea Shell
* Produces a helical shell.
* Random Cluster
* Generates a cluster of the children´s nodes.
* Loft
* Similar to the Loft creator.
* Sweep Interpolate
* An expanded Sweep creator allowing for manipulating the cross section.
And..
* Solines 2D: Bounce
* Useful for simple dynamics of balls / elastic objects
* Can be deployed in creators / spline tracks / particle meshes
* Splines 2D: Dragon
* Various recursive / fractal options (square, triangular, hexagonal)
* Splines 2D: Sine Wave
* self-explanatory
* Splines 2D: Spirals
* self-explanatory, various options (Archimedes, square/...)
* Splines 2D: Tree
* recursive / fractal bifurcation
@Helmut I want to use some of these scripts, but I'm not finding them in the scripts downloads.. I'm not sure if you used the names the authors gave them? For example, I wanted to check Splines 2D: Dragon.. and a few others, but I can't find them.. what am I missing?
Thanks!
#26
* Poly To Spline
* generates a set of splines from the edges of a mesh.
* Particle Connector
* generates splines to connect the elements of a particle mesh.
* Pathed Helix
* applies a helix to a given axial spline.
* Blow Up
* simulates the explosion of an n-faced mesh.
* Hair
* generates hair, fur and similar fibrous clusters.
* Spline Wrap
* This floats a polygonal mesh onto the axis of a given spline.
So where do you actually get these scripts? Thank you. Bman.
Helmut
#28
* You may also want to check the website of Hiroto Tsubaki :)) thank you for your excellent scripts). I believe it is called something like TresGraficos, but you need to check the precise address in the subforum Frank has mentioned above.
