Cheetah3D 7.4.1 Release
This may be an older problem. The UV mapper tool rotation isn't working properly.
With the mapper set to Flat, rotate P 90 degrees, then rotate H 12 degrees and B 12 degrees.
H and B are now rotating in the same direction only opposite.
Update check still isn't working for me. Has not been working for some time.
Can you make a short video/gif? I´m not able to recreate this behaviour.
I remember hearing about changing over to xyz but I didn't notice it happened, or that it was changed back.
Here's a shot with the same rotation on both the UV Mapper and the Object.
As you can see they rotate on a different axis.
