That is how it works right now; just polygons are hidden. Otherwise Martin will have to implement edge/point hide for every polygon tool available.
Is there a reason to nest objects rather than Boolean add?
I now understand. Thanks as for nested do you mean merged? And as for only used in Booleans, I used this example because it is where I noticed it first. Again thanks.
I never thought of using a Boolean. To get rid of extra polys,lines,points. So collapsing the Boolean would be like merging but no extra polys,lines,points. Is this correct?
