Import a .jas file without changing resolution?
uncle808us
I've been searching Google and the forums here for the answer, but would like to get on with my project.
If someone could give me a quick answer I would be grateful.
How can I import a Cheetah 3D file .jas so that it does not change the render resolution?
Can it be done?
Thanks.
frank beckmann
Not that I know. But that seems not right because you want to add/import into an existing scene which most likely has a higher priority - and each jas-file import changes Resolution. Not sure if that´s really intentional.
What I´d do is open that second jas-file and copy&paste what you need from it into your scene you´re working on.
uncle808us
#3
Thanks Frank. It doesn't seem right to me either. I been doing the copy paste but was wishing by now maybe Martin had fixed this. Oh Well maybe he'll read this Post.
uncle808us
#5
Frank Thank you. I am totally ignorant on the use of "Smart Folders" I will do some research into this.
Meanwhile, ( and I understand you are very busy) If you could refer me towards any study helps I would appreciate it.
This applies to anyone else reading this thread. Smart Folders and the use there of has always confused me.
Thanks to all concerned .
Shift Studio
#6
I was just thinking 'smart folder' as I was reading this. Then there it was.
@uncle808us - smart folders are not voodoo. I just say this because we've discussed it before I think. Its just a way to link another file into the current file. There are a few caveats - specifically one comes to mined > when materials need to be updated requires some specific procedures. But you'll figure that out. I can't image working without smart folders personally.
If you want to break the link, that's easy enough too. Just 'make editable'.
good luck.
--shift studio.
uncle808us
#7
good luck.
--shift studio.
Hi Shift, I too remember a discourse about smart folders but I can't find that thread.
What would be the procedure for importing a .jas file to a smart folder in a project so it won't change the current projects resolution?
If you have the time please. Thanks.
frank beckmann
#8
Simply add a "Smart folder" to your scene and go->External file:->Load
Don´t worry about the extra camera - your resolution won´t be altered.
Removing a file via same procedure. To unlink the external file and if you want to work on the externals any further I recommend to double-click the smart-folder icon to make it a group/folder.
