When using the particle spline should the objects align with the points on the spline? Mine don't.
Also why doesn't the spline changes update automatically ?
Does it need to align with the points of a linear spline? When it´s a curved spline the spreading will be equalised along the distanceWhen using the particle spline should the objects align with the points on the spline?
Good question for Martin -it would be cool for animation purposes.Also why doesn't the spline changes update automatically ?
The spreading is the same.You may want the Chain Creator.
Then no particle tag...You may want the Chain Creator.
Thanks Frank, True.Does it need to align with the points of a linear spline? When it´s a curved spline the spreading will be equalised along the distance
Good question for Martin -it would be cool for anumation purposes.
Not sure what you're trying to do. Can you show us something?Then no particle tag...
Simple really obj on a particle spline move the objects at the spline points. Frank answered this they are spread along the spline.Not sure what you're trying to do. Can you show us something?
If you just want to populate something via particle mesh all you need is points (in an empty polygon object)
