Gizmo arrows larger
You know that you don´t have to hit that arrow point? The whole shaft works for transformation and the thickness is adjustable via preferences.
Yes if I'm thinking correctly the line width is not what I want to increase but the size of but the box and cone on the transform tool.
Yes, I like to see a way to make the cone and box larger.
By the way thanks for the tip: you just need to highlight one axis - then click&drag - no need to hit that cone.
Hi Uncle Bob
* Have a look at the settings for System Prefs / Accessibility / Zoom entry in the left panel:
* The MacOS provides a magnifying / zoom option (by default cmd + alt + Plus or Minus key).
* I have only tested this briefly, but there seem to be quite a few parameters to be fiddled with which could support the myopic visual acuity of us post-juvenile canines:unsure::rolleyes::cool:
* PS, after a spot of additional tests:
* I recommend setting the zoom-in factor (probably to 8). The incremental zooms are rather irritating to me.
* There is also a “picture-in picture” option, if that suits your work flow.
I use these already usually on my Retina screen. which makes my renders much smaller than my regular 2009 screen. non retina.
