is there a similar way in C3D to drag a point, edge or polygon around an getting smooth results like using in Blender the function: proportional editing?
Yes, choose the select tool and set a radius for the soft selection in the tool tab.
The transform tool then will effect those points proportionally (point mode only).
Mis beat me by one min getting the image together...you can see this setting in the model window in real time choose one vertice and adjust and watch the area change.
