copy keyframes in hierarchy
hi everyone,
i have a model file and several separate animation files. All share "the same" skeleton.
I know I can copy the keyframes from the animated skeleton onto the static skeleton, and it looks fine, however but I have to do this for all joints individually. with large hierarchies, this is very tiring.
I need a script that takes one joint hierarchy A, loops through it, copies all the keyframes, and applies them to every bone in hierarchy B with the same name. Is there such a script, or would it be possible to provide me with one?
Thanks in advance.
bump.
i read in another thread from a while ago that keyframe data cannot be accessed through scripting, is this still the case?
I’m having the same issue I believe. I want to basically chain the different animation sequences together sequentially along the time line. When I tried doing this the chained or pasted key-frames were coming out wonky, probably because I was only pasting the top part of the hierarchy on the key framed joints. I need to check and see if that was the reason.
Yes it was! I was only copying the root hierarchy.
So Broozar method does work. In other words, you need to manually copy/paste each level of the joint hierarchy manually. When you average around 30 joint hierarchies for the average character... thats a lot of copy/paste & tabbing back and forth between files... its a terrible workflow!
So if the f-curves can be accessed by scripting it would seem that would be a very productive script! Can anyone reference me to a similar script which works with the joint hierarchy, f-curves... as a reference point to write a new script?
You probably miss one step: hold shift key down while selecting the root joint (hierarchical keyframing needs to be enabled) - then copy from time-line (RMB-click->copy) go to new file/hiererchy - again shift select root joint and paste into time-line (RMB-click->paste).
Yep. That did the trick. Seems logical after the fact. But it only takes one little thing in your workflow to be missing... like making sure you select the root hierarchy in both the file you copy from and the file you copy to.
